14 years ago500Khz to 5-10Hz verlog LED divider
Hi, I want to create a 500Khz signal 3.3v to 5-10Hz verlog divider, for a led driver. I have some experience of verlog and ideas. Is there a simpler method of debugging that using...
14 years agoThanks Waiyung.
I am using a de1 board to test divider and will use ext skt input 500KHz. I show the basic code below, for one led channel, could you tell me if it looks correct. =================================================== module tim_counter( clk50M, // clk27M, //extclk, reset_N, ledout ); input clk50M; //output reg ledout; //input clk27M; //input extclk; input reset_N; output reg ledout; reg [15:0]counter; always @ (posedge clk50M or negedge reset_N) //always @ (posedge extclk or negedge reset_N) //always @ (posedge clk27M or negedge reset_N) begin if (!reset_N) begin counter <= 16'd0; ledout <= 1'b0; end else if (counter==16'd5000) begin counter <= 16'd0; ledout <= ~ ledout; end else begin counter <= counter +1; end end endmodule =================================================== I use a top.v file and a pll.v file together with the divider file Thanks Dave
