30-day evaluation license with Quartus Prime Lite 16.0 ??
On August 10 I installed Quartus Prime Lite Edition 16.0. Since then I ran a few University Program Tutorials on a DE1-SoC board successfully. On August 30, upon starting Quartus I got the following alert:
Info (292036): Thank you for using the Quartus Prime software 30-day evaluation. You have 10 days remaining (until Sep 09, 2016) to use the Quartus Prime software with compilation and simulation support. Since then I am getting a similar alert, with daily progress of the countdown, every time I start Quartus. Now, according to the outline of quartus prime edition differences (https://www.altera.com/products/design-software/fpga-design/quartus-prime/download.html), I expected that:- No license should be required for Quartus Prime Lite, whereby
- both compilation (albeit not rapid recompilation) and simulation (with ModelSim Altera Starter Edition) would be supported.
- JSchr18
They just want you to buy the software ... shady marketing apparently. Thanks for sharing your experience I had the same surprise today with the lite software.
The apparent problem is no problem. Today I started quartus again, well after the supposed license expiration date. Happily, no license complaint showed up---the software runs nicely as it used to :)
A couple of hours ago I was wondering: "perhaps the update turned my Quartus Prime Lite installation into a Quartus Prime Standard one?". Now, I archived the projects I've been running so far, and the heading of the archive reports shows that the automatic Quartus Prime Update 16.0.2.222 is not the culprit. For example:
Archive Project report for reaction_tester Sun Sep 4 10:58:07 2016 Quartus Prime Version 16.0.2 Build 222 07/20/2016 SJ Lite Edition So, the installation really is a Quartus Prime Lite one, yet affected by an inappropriate, hanging alert about license expiration... Any other idea? - Altera_Forum
--- Quote Start --- It appears from your description as if you somehow installed not the lite version but the full version --- Quote End --- Indeed, so it seems. However, I just checked the installation log, which is attached. From that I gather the following:- I actually installed Quartus Prime Lite on August 12; I downloaded it on August 10, which nonetheless appears to be the starting date for the daily countdown;
- The log says that both Quartus Prime Help and ModelSim ASE (Free) are installed for the Altera 16.0.0.211 Lite Edition;
- The installation of Quartus Prime Lite 16.0.0.211 automatically started that of Quartus Prime Update 16.0.2.222 as a follow-up.
