17 years ago30 ~ 40mins runtime NIOS PIO fails
Hi, I have a issue with the PIO's... I used the PIOS to gather sensor data from a fifo buffer.. this runs very well pooling 24 sensor data from a buffer at 3msec X 24sensors... The problem is a...
17 years ago@LANZONES
Can you provide more info on your setup and software? Do you use interupts in your software, are you polling the PIO's, do you have other tasks where your Nios could be busy? Is the fysical connection and voltage levels between your ADC's and FPGA OK?
