1pcs field return related with FPGA 10AX032H4F34E3SG
Hi Fairy Tang,
To understand more about your failure, can you help to provide;
1. What is the failure symptom? Please elaborate the failure symptom in detail.
2. When did the failure happen? How did you discover the failure?
3. How did you determine the failure? Please elaborate the procedures.
4. Does the failure unit ever working before failure?
5. Did you swap the failure device to a known good board? Is the failure following the device or board?
Thank you!
Wani
Please consider of confidential info you may share publicly. If you need to send private message/info/attachment, please do let me know.
- Zawani_M_Intel6 years ago
Dear Fairy Tang,
Do you have any update to the request?
Wani
Dear Fairy Tang,
Please do let us know if you have any update on previous request?
Wani
- FTang6 years ago
Hi Wani,
Sorry for response later. I'm stuck by other hot issues in the past 2 months.
Yes, I still need your help to process this FA.
How could I do that?
Thanks so much for your patience!
Best Regards!
Fairy
