14 years ago16Bit YCbCr video port
Dear Altera-Team, we want to convert 16Bit wide YCbCr data comming from our camera to fit to our 8Bit wide camera interface. The idea is to use a CPLD to buffer the 16Bit data and send it out i...
14 years ago1) Hm, as far as I understood, you only need to feed the buffer with ~150MHz. Where you you need the 300 now?
2) You can create a simple design with an synchronus FiFo 16/8 asymmetrical widths and try to fit it into a MAX2 with the free web edition to try if it works or not.
