21 years ago16 bit Processor for MAXII
Hi, Yeah I know it's a NIOS forum, but since NIOS doesnt support MAXII (or is that vice versa?) then here is a solution for those who are interested. This is a project and assembler fo...
20 years agoHi,
I am working on a more efficient version - the base core is hopfully going to finish around 400LE ... I will post here as version two soon. I am working on a very basic Forth compiler for it also. Regards, Steve. --- Quote Start --- originally posted by riple+may 17 2006, 02:59 am--><div class='quotetop'>quote (riple @ may 17 2006, 02:59 am)</div>--- quote start ---
<!--quotebegin-bjskill@Dec 31 2004, 01:27 PM steveg -
when i get an error when i attempt to unzip tiny16.zip. is there a problem with this .zip file?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=3633)
--- quote end ---
--- Quote End --- Hi steve, There is no problem with the zip file. I extracted and compiled the design. It's OK! I am amazed to see the fitter results--only 833 LEs. I will try to add it to my SOPC system as an avalon master component. It's ideal for my "hardware task sheduler" project. By the way, I have tried a 8051 core as an avalon master. It works well, but the LE usage is about 3000. Thank you! <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15423)</div> [/b] --- Quote End ---
