poming
4 years ago14703 MAX 10 Error
I put Ethercat IP (license from Beckhoff) on MAX10 (10M25DAF484C8G) .
When I use quartus 18.1 compile the project, at Assembler stage, show 14703 at message console.
I can not modify any Ethercat...
AR_A_Intel
4 years agoHi
Thanks for update. could you help try the solution in KDB link below https://www.intel.com/content/www/us/en/support/programmable/articles/000074796.html
You may test it see how things go.
Report back if error happen with error message screenshot.
- poming4 years ago
Hi AR_A_Intel,
I have told that I can not modify any Ethercat IP source code, because it is Encrypted IP.
The Encrypted IP use RAM, but I can not read the code, I can not modify the code.
Do your know that any setting within QuartusII for me to set to solve this issue ?
Thank you.
