10 years ago10M50DA clock frequency PLL in EPE
Hi ALTERA-forum, I am new to the FPGA design and now want to start with the EPE. Now I have two problems. One with the frequencies and another with the dissipation. 1. I want to use the...
10 years agoHi Bob,
thank you for the reply. I found this information too, but was a bit unsure about the Clock max frequency, because, as you said the datasheet shows a maximum frequency of 472.5MHz but the spreadsheet shows 600MHz. In case of the max power for the MAX10 device I don't just maxing out the parameters. I looking up for the signals the FPGA will working with and their voltage level and operating frequencies. Then I put a little margin on the frequency. The data to the Dev Kit is looking interesting. The Power tree looks quite similar to mine. Instead of the 12V to 5V I am using 24V to 3.3V. I dont want to use FTDI or HDMI, so I think I am fine by using the 3.3V directly converted from teh 12V. I just have to look for the current ranking. 3.3V @ 3A will do fine. There are just VCCIO and SPI on this rail. Thank your for the links. They help me alot. Best Regards Jérôme
