joe_su
1 year ago10M25DAF484C8G clock input
Hi we have serveral CML clocks output from ethernet PHY which is connected to 10M25DAF484C8G pin P3/R3, V9/V10, how to design the convertion circuit as CML(PHY) to LVDS(max10) ? and if we want to ...
ShengN_altera
1 year agoHi,
If voltage of CML and LVDS are not the same, can use below:
If low speed, you can use voltage divider.
If high speed, you need to use level shifter.
If voltage of CML and LVDS are same, not need to use.
And also the external termination circuit:
The Max 10 lvds IO Standard can refer this :
Sheng
joe_su
1 year agoHi ShengN
one morequestion
I used 10M25DAF484C8G, I need pin L8/L9 configure as diff LVDS output. but IO_1B is on 3.3V power rail.
is it can work on output diff-LVDS clock signal ?
//Joe
