NBK's avatar
NBK
3 years ago
10M16SCU169I7G FPGA open drain ouput pin configuration electrical characteristics
where can i find electrical characteristics of open drain ouput pin configuration for FPGA 10M16SCU169I7G? I need to know maximum pull-up voltage that we can apply externally to the configured open drain output pin and its VOLmax specifications.
Thanking you in advance.
  • lixy's avatar
    lixy
    I wonder if you have any further questions. If not, I will go ahead and mark this issue as resolved.
    Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
    Thank you for your time and cooperation.
    Xiaoyan
  • lixy's avatar
    lixy
    Generally the external pull-up Voltage connected to Open Drain I/O should not be higher than I/O bank's I/O standard voltage.
    Thanks & Regards,
    Xiaoyan
