yfuji's avatar
yfuji
6 years ago
10M02SCU169C8Gと10M04SCU169C8Gを共通基板で使用したいので、10M02SCU169C8Gの NCピンのD2とE2にGNDを接続、NCピンのD3にVCCA3に接続しても問題ないでしょうか
  • yfuji's avatar
    yfuji
    ​Dear CTan1 (Intel)
    Thank you so much!
    yfuji
  • Hi yfuji,
    Thank you for contacting Intel Community. Generally, the NC pins should not be driven any signals. However when the migration feature is enabled in your design, you should always follow the common pin placement as stated in the Quartus Prime software Pin Migration Window in the Pin Planner. Therefore during migration, these NC pins may be connected to power, ground, or a signal trace depending on the common pin migration assignment of the devices selected for migration.
    For 10M02SCU169C8G and 10M04SCU169C8G: by referring to the 'Pin Migration View', you can connect the Pin_D2 and Pin_E2 to GND while Pin_D3 to VCCA3.
    Thank you
    Chia Ling
