9 years ago10M02DCV36I7G - cheap, reliable clocking
I am new to MAX10s and pretty new to FPGAs in general, and will be using 10M02DCV36I7G as a peak detector. The inputs come from two single-ended comparator outputs. I plan to use a number of ph...
9 years agoIf you have the luxury of making repetitive measurements on the same signal, then you could dynamically shift the phase of the PLL (rather than using multiple phase-shifted outputs) and average multiple readings to reduce the effects of random jitter.
