brooksun
3 years ago10AX057使用64line的VBO IP,屏幕出现噪点
客户使用的10AX057需要调节均衡,在使用80cm的同轴线没异常,使用100cm同轴线屏幕出现非常小的雪花点,目前对FPGA端的终端电阻80ohm,还有电压进行调节,屏幕的噪点都没有消失,尝试用toolkit,用了之后客户的VBO就接收不到信号了,这个协助下怎么处理吗?
ZH_Intel
3 years agoHi Brooksun,
Thank you for reaching out.
We would like to clarify some details as below:
1. May I know which Intel FPGA IP that you are using and referring to?
2. Could you share with us your setup and connection diagram? for us to understand more on your issue.
3. May I know which FPGA device you are using?
Looking forward to hear from you.
ZulsyafiqH_Intel
