12 years ago100 Ohm resistor with LVDS receiver
Hi, I am intending to interface ADS5282EVM with Altera DE2 115 Development board via HSMC connector. Referring to the DE2_115_User_manual_2013, page# 41; additionally, when lvds is ...
12 years ago --- Quote Start --- Do I need to assemble an additional 100 Ohm resistor myself ? I am sampling at 20 MHz, is it really necessary to attach it ? --- Quote End --- Yes, you need the 100-Ohm resistor. LVDS drivers output a current, and that current develops a voltage over the 100-Ohm resistor. Without the resistor the LVDS interface will not function. I believe the DE115 board has locations on the PCB for the 100-Ohm termination resistors, but you need to solder them on. You also need to make sure that the I/O bank voltage is changed to 2.5V to be compatible with LVDS - telling Quarus that the bank VCCIO = 2.5V is not sufficient to change the voltage, you have to both change the constraint and physically change the voltage. Cheers, Dave
