1 Port Rom MegaFunc, Only z output, with MIF. Max 10DA. DE10-Lite board
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
- JKASingh5 years ago
I was able to use the MIF file.
However I used a VHDL model of the ROM, instead of the Verilog, as I could not get it working as mentioned.
The link you provided, is about converting MIF to HEX. And I was still able to use the MIF file.
So the problem is still there, when I use the Verilog model, but not when I switched to the VHDL model of ROM.
I have been using the ModelSim Altera version, which comes with Quartus 20.1 Lite edition.
Thank you,
- RichardT_altera5 years ago
Could you help to share a simplified design files with the issue duplicable so I could investigate further?
Please help to provide briefly the steps to reproduce the issue. It helps to duplicate the issue faster.
Hello Intel Support,
It's been over a month now since I provided the files?
Do you have any update?
