18 years ago.rbf file
Hi, I am looking for information on creating a .rbf file. If our board goes dead, we would like to be able to boot it up via USB with just enough data to get the ethernet running, in which we...
DKonz
7 years agoIt can be a permanent setting. I think all versions of Quartus are similar, but specifically Quartus 18.....
Open your project, then from the main screen, Click Assignments > Settings > Device/Board (button in top right corner of pop up window) > Device and Pin Options > Programming Files > Check the Raw Binary Files Check box
Then click OK at the bottom of the pop up window. It's buried good where it hard to find.
