12 years ago.rbf / .jic file problem when changing from Cyclone IV to Cyclone V
Hi, We changed our design from a Cyclone IV (configured via an EPCS64) to a design with a Cyclone V (also configured via an EPCS64). The main parts of the rest of design remained the same. Wi...
12 years agoI recommend you raise a support case with Altera.
Based on what you describe it certainly appears to be a fault that has crept in with the introduction of Cyclone V. Altera may well be able to explain why the behaviour differs to that of Cyclone IV. However, given your direct manipulation of the jic/rbf files - and subsequent success - it's hard to believe the files generated for Cyclone V should be fundamentally different to those for Cyclone IV. Cheers, Alex
