17 years ago.mif file problem
Hi,everyone ! i got a 256*256 gray-scale lena picture.i want to store it into the sram.Due to the limitation of the FPGA internal memory size. i divided the picture into 2 mif file, and send it to th...
17 years agoHi,
The primary idea is not storage by itself but that data should be sent to vga at required speed. Are you sure about your sram size, is it 2MBytes or 2 Mbits? your data is 640x480 bytes. You may also consider sharing fpga memory with sram if so but it gets complicated.
