17 years ago.mif file problem
Hi,everyone ! i got a 256*256 gray-scale lena picture.i want to store it into the sram.Due to the limitation of the FPGA internal memory size. i divided the picture into 2 mif file, and send it to th...
17 years agoHi,
Naturally if you haven't enough storage inside fpga for your application then you need external memory like your sram idea in the first post. You can send data to sram via fpga without the need for mif files or fpga memory.
