17 years ago.mif file problem
Hi,everyone ! i got a 256*256 gray-scale lena picture.i want to store it into the sram.Due to the limitation of the FPGA internal memory size. i divided the picture into 2 mif file, and send it to th...
17 years agoa mif file is meant to be associated with actual memory. Once compiled that memory is initialised by mif values. You can't send mif after mif...you send what is in memory.
If you receive the image into your fpga and want to send it to sram then send it as it comes , you don't need fpga memory to hold it first... if you mean you have your image data in a file(on PC) then let nios read that into sram directly.
