12 years ago--------------Issue With ADP6x01PCI not Recognized-----------------------
Hello Room, I have a PCI card made by Altera (ADP6x01) integrated into a system running with Windows XP. This PCI card is not recognized by Windows although I have the drivers for this PCI car...
12 years agoHi Abdoulaye FALL ,
--- Quote Start --- The only information we have are as per attached file. --- Quote End --- There was no attachment, perhaps you have too few posts. You can just email me the document (my forum name is my email address). --- Quote Start --- tell me what email address should I send you the HDL? --- Quote End --- HDL is not enough. You need HDL + pin constraints + timing constraints. If you had HDL + schematics, you would be able to work out the pin constraints. --- Quote Start --- If you can help me we will arrange a compensation if you find a definitive working solution. --- Quote End --- No need. I'll look at the documentation, and give you advice. You'll have to do the work :) Cheers, Dave
