9 years ago“HSSI_REFCLK_CLUSTER” error on Arria 10
If you run into errors with “HSSI_REFCLK_CLUSTER” when compiling for Arria 10, check if you are using an fPLL to drive core logic. If so, try inserting a clock buffer (ALTCLK_CTRL) between your input pin and the fPLL.
