druva1
5 years agowrong data in rx_parallel_data A10 Transceiver design
I am running a simulation of an Arria 10 native transceiver IP + reset controller IP + Atx_pll
Under the 10GBase Protocol so I can transmit 64 bits of data.
The ref clock is 322.265625 Mhz,...
CheepinC_altera
5 years agoHi,
For your information, I am not really familiar with the 10GBaseR protocol requirement. However, can you try with the idle pattern of 64'h0707_0707_0707_0707 to see if it helps.
Thank you.
- druva15 years ago
Thanks for the trying to help, the 07070707 didn't help. But I manage to fix my error by synchronizing certain signals.
