15 years agowriting/reading sram with cyclone3 in vhdl
Hey,
i'm trying to write and read to/from the sram with a cyclone3 fpga on a NEEK. I wrote a little code to check if it's working, but it doesn't and i tried very much around but to no avail. The clk input is driven by a pll with 100Mhz (of course i connected the SRAM_clk to it). I changed the configuration scheme to passive serial to use DATA[0] and DATA[1] as regular IO-pins. So here's the code, maybe someone will notice a mistake i haven't come across.library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity videosync is
port (clk, nRst: in std_logic;
data: inout std_logic_vector(31 downto 0);
addr: out std_logic_vector(20 downto 0);
nCS, nOE, nWE: out std_logic;
nadsc, nbe0, nbe1, nbe2, nbe3: out std_logic;
led0, led1, led2, led3: out std_logic;
flashnOE, flashnCE: out std_logic);
end entity videosync;
architecture behave of videosync is
-- readram signals
type ramState is (write, read);
signal ramst : ramState;
signal ramcount: integer := 0;
signal notWE: std_logic;
signal memoryData: std_logic_vector(31 downto 0);
begin
readram_process: process (clk, nRst) is
begin
if nRst = '0' then
flashnOE <= '1';
flashnCE <= '1';
nadsc <= '1';
nbe0 <= '1';
nbe1 <= '1';
nbe2 <= '1';
nbe3 <= '1';
led0 <= '1';
led1 <= '1';
led2 <= '1';
led3 <= '1';
nCS <= '0';
nOE <= '1';
notWE <= '1';
addr <= (others => '0');
memoryData <= (others => '0');
ramcount <= 0;
ramst <= write;
elsif rising_edge(clk) then
case ramst is
when write =>
if ramcount = 0 then
addr <= std_logic_vector(to_unsigned(ramcount, 21));
memoryData <= "11111111000000000000000000000000";
nadsc <= '0';
ramcount <= ramcount + 1;
elsif ramcount = 1 then
notWE <= '0';
nadsc <= '1';
elsif ramcount = 2 then
notWE <= '1';
else
ramcount <= 0;
ramst <= read;
end if;
when read =>
addr <= std_logic_vector(to_unsigned(0, 21));
nadsc <= '0';
nOE <= '0';
nadsc <= '1';
if data = "11111111000000000000000000000000" then
led0 <= '0';
else
led0 <= '1';
end if;
led1 <= '0';
else
led1 <= '1';
end if;
elsif ramcount = 3 then
led2 <= '0';
else
led2 <= '1';
end if;
nadsc <= '1';
nOE <= '1';
else
null;
end if;
end case;
end if;
end process readram_process;
nWE <= '0' when notWE = '0' else '1';
data <= memoryData when notWE = '0' else (others => 'Z');
end architecture behave; Thanks for your help, trigit. P.S. I don't know when exactly the data should arrive on the bus, so i checked some clock cycles for it with the different LEDs. But none of them is flashing :(
