15 years agowriting/reading sram with cyclone3 in vhdl
Hey, i'm trying to write and read to/from the sram with a cyclone3 fpga on a NEEK. I wrote a little code to check if it's working, but it doesn't and i tried very much around but to no avail. The ...
15 years agoWell, have a look at it. (Please be sure to look at the last lines too!)
I also posted my top-level design and the SignalTap view. I orientated my code at this one: http://alteraforums.net/forum/showpost.php?p=12636&postcount=9 but it still won't work.library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity videosync is
port (clk, testclk, nRst: in std_logic;
data: inout std_logic_vector(31 downto 0);
addr: out std_logic_vector(20 downto 0);
nCS, nOE, nWE: out std_logic;
nadsc, nbe0, nbe1, nbe2, nbe3: out std_logic;
led0, led1, led2, led3: out std_logic;
flashnOE, flashnCE: out std_logic);
end entity videosync;
architecture behave of videosync is
-- readram signals
type ramState is (write, read);
signal ramst : ramState;
signal ramcount: integer := 0;
signal notWE: std_logic;
signal notOE: std_logic;
signal memoryData: std_logic_vector(31 downto 0);
signal memoryAddr: std_logic_vector(20 downto 0);
begin
readram_process: process (clk, nRst) is
begin
if nRst = '0' then
flashnOE <= '1';
flashnCE <= '1';
nadsc <= '1';
led0 <= '1';
led1 <= '1';
led2 <= '1';
led3 <= '1';
notOE <= '1';
notWE <= '1';
memoryAddr <= (others => '0');
memoryData <= (others => '0');
ramcount <= 0;
ramst <= write;
elsif rising_edge(clk) then
case ramst is
when write =>
if ramcount = 0 then
memoryAddr <= std_logic_vector(to_unsigned(0, 21));
memoryData <= "11111111000000000000000000000000";
ramcount <= ramcount + 1;
elsif ramcount = 1 then
nadsc <= '0';
notWE <= '0';
elsif ramcount = 2 then
notWE <= '1';
nadsc <= '1';
elsif ramcount = 3 then
memoryAddr <= std_logic_vector(to_unsigned(1, 21));
memoryData <= "00000000111111110000000000000000";
elsif ramcount = 4 then
nadsc <= '0';
notWE <= '0';
elsif ramcount = 5 then
notWE <= '1';
nadsc <= '1';
data <= (others => 'Z');
else
ramcount <= 0;
ramst <= read;
end if;
when read =>
notOE <= '0';
nadsc <= '0';
if data = "11111111000000000000000000000000" then
led0 <= '0';
else
led0 <= '1';
end if;
led1 <= '0';
else
led1 <= '1';
end if;
led0 <= '0';
else
led0 <= '1';
end if;
led1 <= '0';
else
led1 <= '1';
end if;
if data = "00000000111111110000000000000000" then
led2 <= '0';
else
led2 <= '1';
end if;
elsif ramcount = 6 then
led3 <= '0';
else
led3 <= '1';
end if;
elsif ramcount = 7 then
led2 <= '0';
else
led2 <= '1';
end if;
elsif ramcount = 8 then
led3 <= '0';
else
led3 <= '1';
end if;
elsif ramcount = 9 then
nadsc <= '1';
notOE <= '1';
else
null;
end if;
end case;
end if;
end process readram_process;
nWE <= '0' when notWE = '0' else '1';
nOE <= '0' when notOE = '0' else '1';
nCS <= '0' when notWE = '0' xor notOE = '0' else '1';
data <= memoryData when notWE = '0' else (others => 'Z');
nbe0 <= '0' when notWE = '0' else '1';
nbe1 <= '0' when notWE = '0' else '1';
nbe2 <= '0' when notWE = '0' else '1';
nbe3 <= '0' when notWE = '0' else '1';
addr <= memoryAddr;
end architecture behave;
