15 years agowriting/reading sram with cyclone3 in vhdl
Hey,
i'm trying to write and read to/from the sram with a cyclone3 fpga on a NEEK. I wrote a little code to check if it's working, but it doesn't and i tried very much around but to no avail. The clk input is driven by a pll with 100Mhz (of course i connected the SRAM_clk to it). I changed the configuration scheme to passive serial to use DATA[0] and DATA[1] as regular IO-pins. So here's the code, maybe someone will notice a mistake i haven't come across.library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity videosync is
port (clk, nRst: in std_logic;
data: inout std_logic_vector(31 downto 0);
addr: out std_logic_vector(20 downto 0);
nCS, nOE, nWE: out std_logic;
nadsc, nbe0, nbe1, nbe2, nbe3: out std_logic;
led0, led1, led2, led3: out std_logic;
flashnOE, flashnCE: out std_logic);
end entity videosync;
architecture behave of videosync is
-- readram signals
type ramState is (write, read);
signal ramst : ramState;
signal ramcount: integer := 0;
signal notWE: std_logic;
signal memoryData: std_logic_vector(31 downto 0);
begin
readram_process: process (clk, nRst) is
begin
if nRst = '0' then
flashnOE <= '1';
flashnCE <= '1';
nadsc <= '1';
nbe0 <= '1';
nbe1 <= '1';
nbe2 <= '1';
nbe3 <= '1';
led0 <= '1';
led1 <= '1';
led2 <= '1';
led3 <= '1';
nCS <= '0';
nOE <= '1';
notWE <= '1';
addr <= (others => '0');
memoryData <= (others => '0');
ramcount <= 0;
ramst <= write;
elsif rising_edge(clk) then
case ramst is
when write =>
if ramcount = 0 then
addr <= std_logic_vector(to_unsigned(ramcount, 21));
memoryData <= "11111111000000000000000000000000";
nadsc <= '0';
ramcount <= ramcount + 1;
elsif ramcount = 1 then
notWE <= '0';
nadsc <= '1';
elsif ramcount = 2 then
notWE <= '1';
else
ramcount <= 0;
ramst <= read;
end if;
when read =>
addr <= std_logic_vector(to_unsigned(0, 21));
nadsc <= '0';
nOE <= '0';
nadsc <= '1';
if data = "11111111000000000000000000000000" then
led0 <= '0';
else
led0 <= '1';
end if;
led1 <= '0';
else
led1 <= '1';
end if;
elsif ramcount = 3 then
led2 <= '0';
else
led2 <= '1';
end if;
nadsc <= '1';
nOE <= '1';
else
null;
end if;
end case;
end if;
end process readram_process;
nWE <= '0' when notWE = '0' else '1';
data <= memoryData when notWE = '0' else (others => 'Z');
end architecture behave; Thanks for your help, trigit. P.S. I don't know when exactly the data should arrive on the bus, so i checked some clock cycles for it with the different LEDs. But none of them is flashing :(24 Replies
Well, have a look at it. (Please be sure to look at the last lines too!)
I also posted my top-level design and the SignalTap view. I orientated my code at this one: http://alteraforums.net/forum/showpost.php?p=12636&postcount=9 but it still won't work.library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity videosync is port (clk, testclk, nRst: in std_logic; data: inout std_logic_vector(31 downto 0); addr: out std_logic_vector(20 downto 0); nCS, nOE, nWE: out std_logic; nadsc, nbe0, nbe1, nbe2, nbe3: out std_logic; led0, led1, led2, led3: out std_logic; flashnOE, flashnCE: out std_logic); end entity videosync; architecture behave of videosync is -- readram signals type ramState is (write, read); signal ramst : ramState; signal ramcount: integer := 0; signal notWE: std_logic; signal notOE: std_logic; signal memoryData: std_logic_vector(31 downto 0); signal memoryAddr: std_logic_vector(20 downto 0); begin readram_process: process (clk, nRst) is begin if nRst = '0' then flashnOE <= '1'; flashnCE <= '1'; nadsc <= '1'; led0 <= '1'; led1 <= '1'; led2 <= '1'; led3 <= '1'; notOE <= '1'; notWE <= '1'; memoryAddr <= (others => '0'); memoryData <= (others => '0'); ramcount <= 0; ramst <= write; elsif rising_edge(clk) then case ramst is when write => if ramcount = 0 then memoryAddr <= std_logic_vector(to_unsigned(0, 21)); memoryData <= "11111111000000000000000000000000"; ramcount <= ramcount + 1; elsif ramcount = 1 then nadsc <= '0'; notWE <= '0'; ramcount <= ramcount + 1; elsif ramcount = 2 then notWE <= '1'; nadsc <= '1'; ramcount <= ramcount + 1; elsif ramcount = 3 then memoryAddr <= std_logic_vector(to_unsigned(1, 21)); memoryData <= "00000000111111110000000000000000"; ramcount <= ramcount + 1; elsif ramcount = 4 then nadsc <= '0'; notWE <= '0'; ramcount <= ramcount + 1; elsif ramcount = 5 then notWE <= '1'; nadsc <= '1'; data <= (others => 'Z'); ramcount <= ramcount + 1; else ramcount <= 0; ramst <= read; end if; when read => if ramcount = 0 then notOE <= '0'; memoryAddr <= std_logic_vector(to_unsigned(0, 21)); ramcount <= ramcount + 1; elsif ramcount = 1 then nadsc <= '0'; if data = "11111111000000000000000000000000" then led0 <= '0'; else led0 <= '1'; end if; ramcount <= ramcount + 1; elsif ramcount = 2 then if data = "11111111000000000000000000000000" then led1 <= '0'; else led1 <= '1'; end if; ramcount <= ramcount + 1; elsif ramcount = 3 then if data = "11111111000000000000000000000000" then led0 <= '0'; else led0 <= '1'; end if; ramcount <= ramcount + 1; elsif ramcount = 4 then if data = "11111111000000000000000000000000" then led1 <= '0'; else led1 <= '1'; end if; ramcount <= ramcount + 1; elsif ramcount = 5 then memoryAddr <= std_logic_vector(to_unsigned(1, 21)); if data = "00000000111111110000000000000000" then led2 <= '0'; else led2 <= '1'; end if; ramcount <= ramcount + 1; elsif ramcount = 6 then if data = "00000000111111110000000000000000" then led3 <= '0'; else led3 <= '1'; end if; ramcount <= ramcount + 1; elsif ramcount = 7 then if data = "00000000111111110000000000000000" then led2 <= '0'; else led2 <= '1'; end if; ramcount <= ramcount + 1; elsif ramcount = 8 then if data = "00000000111111110000000000000000" then led3 <= '0'; else led3 <= '1'; end if; ramcount <= ramcount + 1; elsif ramcount = 9 then nadsc <= '1'; notOE <= '1'; else null; end if; end case; end if; end process readram_process; nWE <= '0' when notWE = '0' else '1'; nOE <= '0' when notOE = '0' else '1'; nCS <= '0' when notWE = '0' xor notOE = '0' else '1'; data <= memoryData when notWE = '0' else (others => 'Z'); nbe0 <= '0' when notWE = '0' else '1'; nbe1 <= '0' when notWE = '0' else '1'; nbe2 <= '0' when notWE = '0' else '1'; nbe3 <= '0' when notWE = '0' else '1'; addr <= memoryAddr; end architecture behave; - Altera_Forum
I think that the first thing to investigate is why SRAM_DATA and memorydata are different when you write.
Could you move the
lines outside of the process? Just to be sure the flash is disabled at all times... Did you compare the pin numbers between the board schematic and the pin planner in your project?flashnOE <= '1'; flashnCE <= '1'; - Altera_Forum
OK, i put them outside of the process.
Yeah, i checked the pin numbers several times, also in comparison to other projects provided by altera. - Altera_Forum
Does anyone know, where i can download the cyclone III starter kit control panel? Maybe i could look if any data is written or put some data in it and try to read it separately. I got the board from my university just for my project and didn't get the CD or anything else for it. I tried downloading the CD contents from Terasic but the control panel is not part of it there.
EDIT: ah, just found it myself on alteras ftp server.
