With USB-Blaster, It works on Quartuss II for Program/Verify, but with USB-Blaster II, it does not work due to an error message "cannot recognize Silicon ID for Device 1"
- JohnT_Altera
May I know if you change the TCK frequency? May I know which device are you programming?
You may refer to https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2019/why-i-failed-with-programming-the-intel--max--fpgas-using-intel-.html,
- jchun31
Thank you John for your comment.
I did not change TCK frequency yet. and device is MAX V.
Still worth trying to change Freq to 16Mhz?
Thank you
- JohnT_Altera
Please change it to 6Mhz which is the same frequency as USB-Blaster I.
- jchun31
Hi
Intel FPGA Download Cable II User Guide is referring to "Quartus Prime" but I installed "Quartus II" not prime.
1. Open the command line interface with the Intel Quartus Prime bin directory in your path (for example, C:\<Intel Quartus Prime installed folder> \<Intel Quartus Prime version>\quartus\bin64).
2. Type the following command to change the TCK frequency:
will it be same for Quartuss II?
will it be possible to talk to you on the phone?
Thank you.
- JohnT_Altera
Yes, both is possible. You can also just download the Quartus Prime and do it using the GUI.
- jchun31
Thank you John.
if you don't, could you please advise step by step for instruction? I already installed Prime.
I am not sure what the command line interface with the Intel Quartus Prime bin directory is and cable number.
and cable has to be connected?
Thank you
Jeaho
- JohnT_Altera
If your PC has already set the environment then you should be able to directly performed "jtagconfig --setparam 1 JtagClock 6M" in the terminal or command prompt. This is assume you are only connecting 1 blaster.
