jchun31
6 years agoWith USB-Blaster, It works on Quartuss II for Program/Verify, but with USB-Blaster II, it does not work due to an error message "cannot recognize Silicon ID for Device 1"
JohnT_Altera
6 years agoHi,
If your PC has already set the environment then you should be able to directly performed "jtagconfig --setparam 1 JtagClock 6M" in the terminal or command prompt. This is assume you are only connecting 1 blaster.
