fzhan51's avatar
fzhan51
6 years ago
why PAC N3000 8x10G port5/port6 always Up ?
ping test all passed except port5/port6;port5/port6 shows "up" even QSFPs plugged out.
  • JonWay_altera's avatar
    JonWay_altera
    Could you confirm the status by running below command?
    cat /sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/spi-altera.0.auto/spi_master/spi0/spi0.0/pkvl/status
    Does this recover over a power cycle?
    Do you know how to replicate this issue?
    • fzhan51's avatar
      fzhan51
      cat /sys/class/../status
      0x60
    • fzhan51's avatar
      fzhan51
      rsu bmcimg 06:00.0
      2020-08-16 21:46:39,075 - [[pci-address(0000:06:00.0),pci_id(0x8086,0x0b30)]] performing RSU operation
      2020-08-16 21:46:39,076 - [[pci-address(0000:06:02.2),pci_id(0x8086,0x2f06)]] removing device from PCIE bus
      2020-08-16 21:46:41,803 - waiting 10 seconds for boot
      2020-08-16 21:46:51,813 - rescanning PCIE bus: /sys/devices/pci0000:00/pci_bus/0000:00
      2020-08-16 21:46:57,814 - RSU operation complete
      ---"power cycle" won't work
        JonWay_altera
        So, correct me if im wrong here...
        rsu bmcimg --> wont recover?
        power cycle --> wont recover?
        Always on the same ports i.e. 0,5,6 always UP? even after rsu bmcimg or power cycle?
        Can you check on another card on the same machine? How many cards are showing this problem?
