FVanE1
6 years agoWhy is the GTX clock output of the HPS running at 250 MHz?
We have an Arria 10 FPGA with ARM processor. In Platform Designer one of the EMACs is routed to the FPGA logic. We do not route the GMII Tx data and GTX clock directly from FPGA logic to a PHY, but we want to merge this data stream with other data and send it to a 10G optical link.
If we run the FPGA logic at the GTX clock output of the HPS system, we see each data byte of the GMII interface is sent twice. When measuring the GTX clock we see a frequency of 250 MHz. While we expect 125 MHz for a fixed 1 Gbps interface.
Can someone explain me why the GTX clock output is running at a frequency which is twice the expected frequency?
Frank
