FVanE1
6 years agoWhy is the GTX clock output of the HPS running at 250 MHz?
We have an Arria 10 FPGA with ARM processor. In Platform Designer one of the EMACs is routed to the FPGA logic. We do not route the GMII Tx data and GTX clock directly from FPGA logic to a PHY, but w...
EBERLAZARE_I_Intel
6 years agoHave you tried changing the value of the emac1_clk_hz if that made any changes? You may need to recompile the dtb, uboot, etc. after changing the value.
