Why is the GTX clock output of the HPS running at 250 MHz?
I expected to find a pll_config.h file for the Arria 10, but what I can find in my buildroot software directories is:
./bsp/buildroot/output/build/uboot-tools-2018.03/board/altera/arria5-socdk/qts/pll_config.h
./bsp/buildroot/output/build/uboot-tools-2018.03/board/altera/cyclone5-socdk/qts/pll_config.h
./bsp/buildroot/output/build/uboot-tools-2018.03/board/aries/mcvevk/qts/pll_config.h
./bsp/buildroot/output/build/uboot-tools-2018.03/board/devboards/dbm-soc1/qts/pll_config.h
./bsp/buildroot/output/build/uboot-tools-2018.03/board/ebv/socrates/qts/pll_config.h
./bsp/buildroot/output/build/uboot-tools-2018.03/board/is1/qts/pll_config.h
./bsp/buildroot/output/build/uboot-tools-2018.03/board/samtec/vining_fpga/qts/pll_config.h
./bsp/buildroot/output/build/uboot-tools-2018.03/board/sr1500/qts/pll_config.h
./bsp/buildroot/output/build/uboot-tools-2018.03/board/terasic/de0-nano-soc/qts/pll_config.h
./bsp/buildroot/output/build/uboot-tools-2018.03/board/terasic/de1-soc/qts/pll_config.h
./bsp/buildroot/output/build/uboot-tools-2018.03/board/terasic/de10-nano/qts/pll_config.h
./bsp/buildroot/output/build/uboot-tools-2018.03/board/terasic/sockit/qts/pll_config.h
./bsp/buildroot/output/build/host-uboot-tools-2018.03/board/altera/arria5-socdk/qts/pll_config.h
./bsp/buildroot/output/build/host-uboot-tools-2018.03/board/altera/cyclone5-socdk/qts/pll_config.h
./bsp/buildroot/output/build/host-uboot-tools-2018.03/board/aries/mcvevk/qts/pll_config.h
./bsp/buildroot/output/build/host-uboot-tools-2018.03/board/devboards/dbm-soc1/qts/pll_config.h
./bsp/buildroot/output/build/host-uboot-tools-2018.03/board/ebv/socrates/qts/pll_config.h
./bsp/buildroot/output/build/host-uboot-tools-2018.03/board/is1/qts/pll_config.h
./bsp/buildroot/output/build/host-uboot-tools-2018.03/board/samtec/vining_fpga/qts/pll_config.h
./bsp/buildroot/output/build/host-uboot-tools-2018.03/board/sr1500/qts/pll_config.h
./bsp/buildroot/output/build/host-uboot-tools-2018.03/board/terasic/de0-nano-soc/qts/pll_config.h
./bsp/buildroot/output/build/host-uboot-tools-2018.03/board/terasic/de1-soc/qts/pll_config.h
./bsp/buildroot/output/build/host-uboot-tools-2018.03/board/terasic/de10-nano/qts/pll_config.h
./bsp/buildroot/output/build/host-uboot-tools-2018.03/board/terasic/sockit/qts/pll_config.h
Are you sure this is also working for Arria 10 devices? And how is the link made between Quartus and the pll_config.h file?
Frank
