why cyclone v soc HPS running linux can only get 200 BogoMIPS?
Hi El,
this is linux booting info:
NAND read: device 0 offset 0x180000, size 0x80000
524288 bytes read: OK
## Starting application at 0x3FF5A5A4 ...
## Application terminated, rc = 0x0
## Flattened Device Tree blob at 00a00000
Booting using the fdt blob at 0x00a00000
Loading Device Tree to 03ff7000, end 03fffe5d ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.73-ltsi ([email protected]) (gcc version 4.9.4 20151028 (prerelease) (Linaro GCC 4.9-2016.02)) #16 SMP Sun Feb 16 23:03:21 CST 2020
[ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Altera SOCFPGA Cyclone V
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] percpu: Embedded 44 pages/cpu @ddbcd000 s150720 r8192 d21312 u180224
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 121920
[ 0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mtdblock6 rw rootfstype=jffs2 init=/init mem=480M log_buf_len=1048576
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 472776K/491520K available (8192K kernel code, 532K rwdata, 1628K rodata, 1024K init, 1158K bss, 18744K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xde800000 - 0xff800000 ( 528 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xde000000 ( 480 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0900000 (9184 kB)
[ 0.000000] .init : 0xc0c00000 - 0xc0d00000 (1024 kB)
[ 0.000000] .data : 0xc0d00000 - 0xc0d85358 ( 533 kB)
[ 0.000000] .bss : 0xc0d8ba3c - 0xc0ead4d0 (1159 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] ftrace: allocating 26827 entries in 79 pages
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] L2C-310 erratum 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 8 ways, 512 kB
[ 0.000000] L2C-310: CACHE_ID 0x410030c9, AUX_CTRL 0x46060001
[ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
[ 0.000006] sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 21474836475ns
[ 0.000019] Switching to timer-based delay loop, resolution 10ns
[ 0.000247] GIC: PPI13 is secure or misconfigured
[ 0.000280] GIC: PPI13 is secure or misconfigured
[ 0.000442] Console: colour dummy device 80x30
[ 0.000469] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=1000000)
[ 0.000484] pid_max: default: 32768 minimum: 301
[ 0.000603] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000614] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001141] CPU: Testing write buffer coherency: ok
[ 0.001361] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001660] Setting up static identity map for 0x100000 - 0x100060
[ 0.001779] Hierarchical SRCU implementation.
[ 0.002273] smp: Bringing up secondary CPUs ...
[ 0.002692] smp: Brought up 1 node, 1 CPU
[ 0.002705] SMP: Total of 1 processors activated (200.00 BogoMIPS).
[ 0.002713] CPU: All CPU(s) started in SVC mode.
[ 0.003474] devtmpfs: initialized
[ 0.008026] random: get_random_u32 called from bucket_table_alloc+0xfc/0x250 with crng_init=0
[ 0.008300] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.008502] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008521] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.857848] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xdc
[ 0.864180] nand: Micron MT29F4G08ABADAWP
[ 0.868223] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 0.877649] Bad block table found at page 262080, version 0x01
[ 0.884655] Bad block table found at page 262016, version 0x01
[ 0.891826] 8 ofpart partitions found on MTD device denali-nand
[ 0.897748] Creating 8 MTD partitions on "denali-nand":
[ 0.902956] 0x000000000000-0x000000080000 : "NAND Flash Boot Area 512KB"
[ 0.910558] 0x000000080000-0x000000100000 : "NAND Flash u-boot 512KB"
[ 0.918177] 0x000000100000-0x000000180000 : "NAND Flash u-boot parameters 512KB"
[ 0.926673] 0x000000180000-0x000000200000 : "NAND Flash FDT 512 KB"
[ 0.933932] 0x000000200000-0x000000e00000 : "NAND Flash fpga config rbf file 12 MB"
[ 0.942726] 0x000000e00000-0x000001400000 : "NAND Flash kernel 6 MB"
[ 0.950306] 0x000001400000-0x000011400000 : "NAND Flash ubi rootfs 224 MB"
[ 0.959677] 0x000011400000-0x000011e00000 : "NAND Flash baremetal image 10 MB"
[ 0.968323] cadence-qspi ff705000.flash: couldn't determine fifo-depth
[ 0.974830] cadence-qspi ff705000.flash: Cannot get mandatory OF data.
- SimoneBo6 years ago
I'm facing with the same issue....
Boot logs show me:
" Switching to timer-based delay loop, resolution 10ns
Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=1000000) "
Moreover I'm getting a slower boot time respect when I used a 3.10.36-ltsi linux-socfpga kernel.
@AWu6 did you get a slower boot too? Did you find a fix for that issue?
@EBERLAZARE_I_Intel, I think is a Devices Tree related issue, may you share an example of dts working on 4.x linux-socfpga kernel?
Thanks a lot in advance,
Simone
- AWu66 years ago
Hi Simon,
not fix 200 BogoMIPS issue, i can't get any more help about this issue, and i have checked PLL configuration, it's configured as 800MHz main clock frequency.
for slow boot issue, i think it may be related to your boot media speed, such as NAND FLASH or QSPI FLASH. i have encountered it, root cause is low speed configure of NAND FLASH controller.
best regards
alex
HI AWu6,
thanks for the replay.
The slow boot, and generally the low performance of the processor was caused by a wrong definition of clocks/PLL/oscillators section in the devices tree. I update that device tree section with one found in linux-socfpga, (4.14.x) and everything goes well. Slow boot and generally low performance disappeared.
That devices tree works well with 3.10.x kernel but with 4.14.x no.
With the old device tree seems that the 4.14.x kernel started using a clock frequency lower than 800MHz. No one log or indication was present at startup in boot logs.
Have a good day,
Simone
