Why can't I modify the sysfs
Hi
I was going through a tutorial on a DE10-Nano on how to make custom overlays, and I seem to have hit a bit of a puzzle.
https://rocketboards.org/foswiki/Documentation/HOWTOCreateADeviceTree
At one stage, it requires me to create a directory and update values in sysfs.
sudo mkdir /sys/kernel/config/device-tree/overlays/my-cv-fpga-overlay
sudo echo my_cv_fpga_overlay.dtb > /sys/kernel/config/device-tree/overlays/my-cv-fpga-overlay/path Problem is I cannot seem to do so. the command returns "Operation not permitted" error message.
I tried the LDXE linux image from terasic and also a rootfs/kernel that I made based on ubuntu base and kernel 4.9...lsti
https://github.com/rsarwar87/altera-soc-rootfs
Presumably it is some kernel configuration that I need to turn on maybe to allow modification of sysfs? I was wondering if anyone could kindly shed some light on this puzzle.
RD
Hi Anand
Thank you for your reply. Unfortunately logging in as root did not help.
however, I remounted the configfs with the following code and was able to edit it like normal.
sudo mount -t configfs none /configBr
R
- AnandRaj_S_Intel
Can you run the command in root privilege and without sudo.
like :root@socfpga:~# mkdir /sys/kernel/config/device-tree/overlays/my-cv-fpga-overlay
Anand Raj Shankar
- RSarw
Hi Anand
R
