Why 390.625MHz clock to F-Tile Reference fequency
Hi Thulas,
Based on the documents, the 390.625 MHz clock from the Si5518 on the Agilex 7 M-Series development kit is not meant to be the standard F-Tile Ethernet PMA reference clock.
For F-Tile Ethernet Hard IP, the usual PMA reference clock is:
- 156.25 MHz for standard Ethernet modes
- 312.5 MHz or 322.265625 MHz only for some specific FGT cases without AN/LT
So to answer your questions:
- The external 390.625 MHz clock on the M-Series board seems to be there mainly for timing-related use cases such as IEEE 1588 TOD/PTP, and also for board-level SyncE/CPRI style clocking, rather than as the normal Ethernet PMA refclk.
- For Ethernet Hard IP, 390.625 MHz lines up with the TOD clock requirement in basic timestamp accuracy mode. It also matches the internally generated o_clk_tx_div and o_clk_rec_div clocks for many Ethernet rates. So it makes more sense as a timing or transceiver support clock than as the main PMA reference input.
So the short version is:
- use 156.25 MHz as the normal F-Tile Ethernet Hard IP PMA reference clock unless your selected FGT mode specifically allows one of the alternate documented refclk values
- treat the on-board 390.625 MHz clock as mainly intended for PTP/TOD, SyncE/CPRI, or related timing/transceiver use cases, not as the default Ethernet PMA reference clock
pavee
In Agilex® 7 M-Series Evaluation Kit schematics, I noticed that the 390.625 MHz clock generated by the Si5518 is distributed through the Si5395 and Si5391 clock devices to several FPGA-related interfaces, including DDR5, HBM, and the SDM. (Please refer to the attached schematic.)
I understand that 390.625 MHz is commonly associated with SyncE and Ethernet timing applications.
Could you please clarify the following?
1. What is the purpose of using the 390.625 MHz clock generated by the Si5518 as the reference for the Si5395/Si5391 clock distribution network?
2. Why is this clock distributed to the DDR5, HBM, and SDM clocking circuitry on the Agilex 7 M-Series Evaluation Kit?
3. Is the 390.625 MHz clock intended only as a common low-jitter board reference from which the Si5395/Si5391 generate the required interface clocks, or is there a specific architectural reason for selecting 390.625 MHz instead of another reference frequency?
4. Is this clocking scheme specific to the evaluation kit, or is it the recommended clocking architecture for customer designs that use Ethernet, SyncE, and HBM together?
I could not find an explanation of this clocking architecture in the available documentation, so any clarification would be greatly appreciated.
Thank you.
- paveetirrasrie_Altera2 months ago
Hello Thulasi,
1. Purpose of the Si5518 390.625 MHz reference into the Si5395/Si5391 distribution network
390.625 MHz is the standard parallel-clock frequency for F-Tile Ethernet at 25G/50G/100G/200G/400G rates. The divided clock output o_p0_clk_tx_div supports 156.25 MHz for 10GE, 312.5 MHz for 40GE, and 390.625 MHz for all other Ethernet modes. Agilex 7 · Transceiver/PHY It is also the required TOD (Time-of-Day) clock frequency for PTP and SyncE applications at those rates. The TX TOD input clock i_clk_tx_tod frequency varies based on the Ethernet rate and timestamp accuracy mode in Basic timestamp accuracy mode it is 390.625 MHz for 25GE/50GE/100GE/200GE/400GE. Agilex 7 · Clock
The Si5518 is a jitter-attenuating clock IC well-suited to SyncE/PTP applications. By generating a clean, low-jitter 390.625 MHz output, it provides a single high-quality frequency anchor from which the Si5395 and Si5391 (wideband jitter-attenuating synthesizers) can derive all the other interface clocks needed on the board DDR5 reference, HBM UIB PLL reference, NoC PLL reference, SDM clock, and the Ethernet/SyncE clocks through integer or fractional division/multiplication.
2. Why is this clock distributed to DDR5, HBM, and SDM circuitry?
The Si5395/Si5391 are not passing 390.625 MHz directly to those interfaces. They use it as their input reference and synthesize the correct output frequencies for each downstream consumer. For example:
The ref_clk signal for the Agilex 7 M-Series EMIF IP DDR5 Component variant is the reference clock used by the EMIF PLL. Agilex 7 · General That PLL reference has its own required frequency (not 390.625 MHz directly), which the Si5395/Si5391 generate from the 390.625 MHz input.
Similarly, the HBM2E UIB PLL and the NoC PLL each require their own dedicated reference clocks, requiring a pin location assignment for the NoC PLL (one for top and one for bottom hard memory NoC) and the UIB PLL (one for top and one for bottom HBM2E), plus a pin location for the reference clock of the EMIF PLL for any EMIF IP instance. Planning NoC PLL and I/O PLL
There is no connection between the SDM and the hard memory NoC, and all signals from the SDM bypass the hard memory NoC Agilex 7 · EMIF/DDR so the SDM clock path is independent and the Si5391/Si5395 simply synthesize the appropriate SDM reference from the same 390.625 MHz source.
Using a single upstream reference for all synthesizers simplifies board design and ensures all generated clocks are frequency-coherent (traceable to a common source), which is important for SyncE operation.
3. Is 390.625 MHz chosen as a convenient common reference, or is there a specific architectural reason?
Both, actually. 390.625 MHz is architecturally significant for F-Tile Ethernet/SyncE/PTP it is not an arbitrary choice. For 25G/50G Ethernet, the minimum supported clock rate for MAC client asynchronous FIFO operation is 390.625 MHz. Agilex 7 · Clock Using it as the board-level reference means the Si5518 output can be routed directly (or with minimal buffering) to the F-Tile TOD/SyncE clock inputs, while the Si5395/Si5391 simultaneously derive all other required frequencies from it. This avoids needing a second independent reference oscillator for Ethernet timing, which would complicate SyncE holdover and traceability.
The 390.625 MHz value is also integer-related to 156.25 MHz (÷2.5, or equivalently ×2.5), which is the standard F-Tile PMA reference clock frequency. The PMA reference clock is driven by the F-Tile Reference and System PLL Clocks IP; 156.25 MHz is the recommended frequency for all Ethernet modes and is the only supported frequency when using FHT PMA or when auto-negotiation and link training is enabled. Agilex 7 · Transceiver/PHY The Si5395/Si5391 can cleanly divide 390.625 MHz to produce 156.25 MHz (÷2.5) or other required frequencies.
4. Is this kit-specific, or is it the recommended architecture for customer designs?
The evaluation kit's clocking topology a jitter-attenuating SyncE-capable PLL (Si5518) feeding wideband synthesizers (Si5395/Si5391) that fan out to all major clock domains is a well-established board design pattern for designs that combine Ethernet/SyncE/PTP with HBM and DDR5. The Agilex 7 FPGA M-Series Development Kit (HBM2e Edition, 3x F-Tile & 1x R-Tile) offers programmable clocking with Si5391, Si5392, Si5395, Si5332, and Si5518. Agilex 7 · General The kit is explicitly designed to demonstrate this kind of multi-domain clocking.
For customer designs combining these interfaces, the key architectural principles to carry over are:
Use a single low-jitter, SyncE-traceable reference (e.g., Si5518 or equivalent) as the upstream anchor.
Use jitter-attenuating synthesizers (Si5395/Si5391 class) to fan out to each interface's PLL reference pin, keeping all clocks frequency-coherent.
Each F-tile system must instantiate one F-Tile Reference and System PLL Clocks IP Ethernet , so your board must supply the appropriate reference to each F-tile's clock input.
Using a single TOD clock for multiple 25GE Ethernet IP instances violates the F-Tile Ethernet Hard IP requirement for separate TOD clocking Agilex 7 · Ethernet so your synthesizer fan-out must provide independent TOD clock paths per port when PTP is enabled.
Hope this helps.
Pavee
- Thulasi2 months ago
I have the following two queries:
- Is it possible to use separate oscillators (reference clock) to generate the reference clocks for the DDR5, HBM, SDM, HPS and NoC interfaces of the Agilex M FPGA, instead of deriving these clocks from the 390.625 MHz clock generated by the Si5518 PLL? Please confirm.
2. Please find the attached screenshot from Section 4.4.2, "PTP Timestamp Accuracy," of the F-Tile Ethernet Hard IP User Guide. The guide states:
"Any 390.625 MHz frequency clock source can drive the TOD clock in 10GE mode."
Could you please confirm whether the 390.625 MHz clock generated by the Si5518 PLL and connected to the F-Tile reference clock pins is the clock source that drives the ToD clock when the F-Tile is operating in 10GE mode and for other ethernet modes this clock source is not used(required).
Thank you for your assistance.
- paveetirrasrie_Altera24 days ago
Hello Thulasi,
For DDR related queries, please file a new Forum. It will get assigned to DDR expert to help with the queries.
2. The Si5518 390.625 MHz signal can be used as the TOD clock in 10GE Basic accuracy mode only if it is explicitly routed to i_clk_tx_tod and i_clk_rx_tod. Merely connecting it to the F-Tile reference-clock pins does not make it the TOD source. The guide’s diagram treats the TOD clock as a separate connection.
Important distinction:
- F-Tile reference clock (i_clk_ref): PMA/transceiver reference clock. The current guide lists 141, 156.25, 312.5, or 322.265625 MHz depending on PMA/configuration—not 390.625 MHz. Verify the Si5518 frequency against the selected PMA and F-Tile Reference/System PLL parameters.
- 10GE Basic TOD clock: Any stable 390.625 MHz source is valid, including the Si5518 output, provided it is separately connected to the TOD clock inputs.
- 25–400GE Basic mode: A 390.625 MHz TOD clock is still required; the guide recommends using each instance’s o_clk_tx_div as the TOD-clock source.
- Advanced mode: Use o_clk_tx_div for TX TOD and o_clk_rec_div for RX TOD; for 10GE these are 156.25 MHz, while other listed modes use 390.625 MHz.
Hope I've answered your query.
Pavee
