9 years agoWhich oscilloscope range to use with the onboard clock???
Hello everyone, I'm using a DE2 board for a simple multiplexing system that I have wrote in VHDL. Now, I'm using the onboard clock which is (50 MHz). My question is, if I want to use an oscilloscope ...
9 years agoI don't know about the clock socket, bu I have used buttons etc in the past witout problems (after debouncing) when doing this you need to check the tresholds and max ratings, but I have never used the clock socket. As for the scope what is your changerate? if the signal only changes every other clockcycle you should be right according to nyqvist, but you might need a higher sample rate, on the other hand, why not try the scope you have and see what that does?
