14 years agoWhich memory is better for the NIOS PROCESSOR?
Hi, I'm using the DE1 kit, my project includes a NIOS processor to present data on a color LCD... I'm already using the SRAM for the LCD(to save the picture data on), so I need to decide which...
14 years agoSDRAM. Offen you use flash to hold video frames or images but before you display them you put them into an off-chip frame buffer. SDRAM works well for a frame buffer since a video engine and sequentially access it quickly. I don't know what resolution you are working with but if your SRAM is large enough to hold a couple frames you could use it as well.
