Kavin
6 years agoWhen using RSU, is it necessary to use an external trigger to trig FPGA to load application image?
I got some problems when using RSU in Cycone IV E device: 1: When using RSU, is it necessary to use an external trigger to trigger the FPGA to load the application image? I try to use logic to trig ...
- 6 years ago
The pof_error only performed sanity check and not full check. So if the initial bitstream is correct then it will try to configure the FPGA with application image. The pof_error will only detect if there is some error on the initial bitstream.
JohnT_Altera
6 years agoHi,
Could you share with me your design? The pof_error is used to monitor that there is application image bitstream issue where you should stop reconfiguring your FPGA to application image.
