What's the reason of “Write per-bit deskew fail” during DDR4 calibration
Hi SYiwe,
Have you solved your problem about JTAG interface
How did you solve it?
I have the same problem as you.
I'll be appreciated if you can tell me the answer.
Thanks, regards.
- SYiwe7 years ago
If your JTAG circuit is correct, probably beacuse your download cable doesn't support Arria10. I suggest you to change to a newer download cable, and it's better to be produced by Altera.
Regards.
- 阳石0006 years ago
The problem has been solved.I changed a USB BLASTER II. THANKS!
I have a new problem.
When I download jjc file to EPCQL1024 through JTAG interface, an error occurs "Error (209014): CONF_DONE failed to go high in device".
Observe DCLK with an oscilloscope and find that there is no clock and nCSO is not pulled down.(EPCQL1024 replaced by MT25QU01G)
Have you ever had such a problem?
Thanks, regards.
