XG_Kang
6 years agoWhat would happen if VCCPD and VCCIO were delayed tens of minutes to power up after VCC was powered up already for 5CEA9 device?
In a 5CEA9 design, first power up VCC, and then VCCPD & VCCIO in all IO banks are not powered up right now, but at sometime later in tens of minutes,what will happen to the FPGA device? Will the FPGA...
XG_Kang
6 years agoThanks for your reply, Anand,
The reason that I do this is to lower the power consumption of the FPGA device when the FPGA is not needed to work. So I want to shut some power rail but at the same time the FPGA should keep the configuration correctly.
I will check AN662 carefully.
