XG_Kang
6 years agoWhat would happen if VCCPD and VCCIO were delayed tens of minutes to power up after VCC was powered up already for 5CEA9 device?
In a 5CEA9 design, first power up VCC, and then VCCPD & VCCIO in all IO banks are not powered up right now, but at sometime later in tens of minutes,what will happen to the FPGA device? Will the FPGA...
AnandRaj_S_Intel
6 years agoHi,
- VCCPD is monitored by POR circuitry, So you have to power on it within the maximum power supply ramp time, tRAM. If tRAMP is not met, the Cyclone V device I/O pins and programming registers remain tri-stated, during which device configu‐ ration could fail.
- VCCIO is not monitored by POR so you can powers up at any time.
Are you using same regulator for VCCPD and VCCIO ?
Please check AN662, Power Management in Cyclone V Devices & Cyclone V Devices handbook for POR requirement.
Anand
