MLash2
7 years agoWhat tool or example used to translate Arduino/Teensydino code to NIOS code (C/C++)?
FawazJ_Altera
7 years agoHello sir,
Arduino uses special functions of C language which is not supported in Nios II. the code that will be used to run the Arduino needs to be re-written in a plain C format to be compatible with Nios II. If there are libraries behind that Arduino code, you can use them directly with Nios II. However, this can be easily done if your libraries are written in C, if they are written in C++, you might find some challenges in handling them for Nios II since C++ requires large amount of memory to run on Nios II.
Hope this might help.
