AKAYA
7 years agowhat is the difference between function main() and alt_main()??
hello, i need to create a customized boot code for my application. so, according to the software manual i can make use of alt_main() for implementation of my own coding.. can someone please expl...
KhaiChein_Y_Intel
7 years agoHi AKAYA,
Normally, your program’s entry point is the function main(). There is an alternate entry point, alt_main(), that you can use to gain greater control of the boot sequence. The difference between entering at main() and entering at alt_main() is the difference between hosted and free-standing applications.
Reference: https://www.intel.com/content/www/us/en/programmable/documentation/mwh1416947091611/mwh1416946758774.html
AKAYA
7 years agothanks for the reply....
can we use both alt_main() and main() in same project?
if its possible then will the alt_main() fuction calls the main() function by default or we need to call the function explicitly
