TNine
7 years agoWhat is the appropriate way to specify the SDC for "..was determined to be a clock but was found without an associated clock assignment."
I already read https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an545.pdf?language=en_US and https://forums.intel.com/s/question/0D50P00003yyHQNSA2/diagnosing-signal-was...
TNine
7 years agoThank you very much, and sorry for the late reply. I could not make it work with get_pins, and switched to get_nodes. This is how the sdc now reads:
create_generated_clock -source [get_ports enc_a] -multiply_by 1 [get_nodes {busRotaryEncoder:busRotaryEncoder|metaA}] -name metaA
create_generated_clock -source [get_nodes {busRotaryEncoder:busRotaryEncoder|metaA} ] -multiply_by 1 [get_nodes {busRotaryEncoder:busRotaryEncoder|stableA}] -name stableAHowever I get a new warning.
Warning (332088): No paths exist between clock target "busRotaryEncoder:busRotaryEncoder|metaA" of clock "metaA" and its clock source. Assuming zero source clock latency.
Warning (332088): No paths exist between clock target "busRotaryEncoder:busRotaryEncoder|stableA" of clock "stableA" and its clock source. Assuming zero source clock latency.
Why does quartus detect no path even if there is the above mentioned synchronization?
