What does it mean when configuration fails, and nSTATUS stays low and pulses high?
Hello MShafig
I have attached here a sequence of errors that we get when trying to configure the device. The examine command works, the erase works 50% of the time but the verify, blank check and the program never works. I have used both Quartus 17.1 and 18 programmer for this.
Warning (210120): MAX 10 information is incomplete. The ISP clamp functionality will be disabled.
Info (209060): Started Programmer operation at Wed Mar 06 17:03:47 2019
Info (209017): Device 1 contains JTAG ID code 0x031020DD
Info (209016): Configuring device index 1
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Wed Mar 06 17:03:48 2019
Info (209060): Started Programmer operation at Wed Mar 06 17:03:56 2019
Error (209053): Unexpected error in JTAG server -- error code 35
Info (209061): Ended Programmer operation at Wed Mar 06 17:03:57 2019
Info (209060): Started Programmer operation at Wed Mar 06 17:03:59 2019
Error (209014): CONF_DONE pin failed to go high in device 1. Make sure all communication cables are securely connected, select a different device, check the power on the target system, or make sure all nCE pins are connected to GND. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Info (209061): Ended Programmer operation at Wed Mar 06 17:04:00 2019
Info (209060): Started Programmer operation at Wed Mar 06 17:04:11 2019
Error (16353): Expected the Max 10 device at index 1 to be of type analog, but detected device of type invalid instead. Ensure that you are using the correct programming file.
Info (209061): Ended Programmer operation at Wed Mar 06 17:04:11 2019
Info (209060): Started Programmer operation at Wed Mar 06 17:04:15 2019
Error (209029): Can't invoke Programmer to configure device
Info (209061): Ended Programmer operation at Wed Mar 06 17:04:15 2019
Info (209060): Started Programmer operation at Wed Mar 06 17:04:16 2019
Error (209015): Can't configure device. Expected JTAG ID code 0x031020DD for device 1, but found JTAG ID code 0x00000155. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the Chain Description File (.cdf).
Info (209061): Ended Programmer operation at Wed Mar 06 17:04:16 2019
Info (209060): Started Programmer operation at Wed Mar 06 17:04:20 2019
Error (209040): Can't access JTAG chain
Info (209061): Ended Programmer operation at Wed Mar 06 17:04:20 2019
Info (209060): Started Programmer operation at Wed Mar 06 17:04:22 2019
Info (209061): Ended Programmer operation at Wed Mar 06 17:04:23 2019
Info (209060): Started Programmer operation at Wed Mar 06 17:04:25 2019
Error (209015): Can't configure device. Expected JTAG ID code 0x031020DD for device 1, but found JTAG ID code 0x019020DD. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the Chain Description File (.cdf).
Info (209061): Ended Programmer operation at Wed Mar 06 17:04:25 2019
Info (209060): Started Programmer operation at Wed Mar 06 17:04:26 2019
Error (209015): Can't configure device. Expected JTAG ID code 0x031020DD for device 1, but found JTAG ID code 0x018800DD. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the Chain Description File (.cdf).
Info (209061): Ended Programmer operation at Wed Mar 06 17:04:26 2019
Info (209060): Started Programmer operation at Wed Mar 06 17:04:30 2019
Info (209061): Ended Programmer operation at Wed Mar 06 17:04:30 2019
Info (209060): Started Programmer operation at Wed Mar 06 17:04:32 2019
Info (209061): Ended Programmer operation at Wed Mar 06 17:04:32 2019
Info (209060): Started Programmer operation at Wed Mar 06 17:04:33 2019
Info (209061): Ended Programmer operation at Wed Mar 06 17:04:33 2019
thank you
