Ophir_eng
1 year agoWeak pull-ups \ tri-state at cyclone v soc
Hello, we are doing a bring up for a new card, we are seeing a phenomenon and trying to understand it, the fpga is loaded by the hps, and the nconfig pin is held constant at a logical 1, when the card...
AqidAyman_Altera
1 year agoHello,
In the Cyclone V Pin Connection Guideline, it mentioned:
When you use the nCONFIG pin in a passive configuration scheme, connect the pin directly to the
configuration controller. When you use the nCONFIG pin in an AS configuration scheme, connect
the pin through a 10-kΩ resistor tied to VCCPGM. When you do not use the nCONFIG pin, connect
the pin directly or through a 10-kΩ resistor to VCCPGM.
