we want to apply FA
Email Details :
a)Contact name and email address: Bruce.Wu/[email protected]
b)Company details: Flex.
c)Debugging steps that was done :
1) Took the failed board (FDO230700G6) to do failure analysis, and review the failed log
from 2C station as following:
Initializing Hardware ...
Checking for PCIe device presence...
%ERROR% - Did not find CPLD. Read failure!
%ERROR: Critical device not found on 00:01.00
%WARNING: Resetting...
2)Put the failure board to debug station at room temperature, then power on, found
it is not stable, sometimes it can be boot up normally; sometimes it failed with get
ROMMON symptom (it can be duplicated), the failure log and Post code failed
status is as same as it happened at 2C station.
3)Based on the fail log and debug experience before, it is related with FPGA(U1_F1),
we checked the FPGA and the parts around with it, no process issue found, also
measured the impedance and voltages related with FPGA and CPU and compared
with a known pass board, all of them are normal
4)Visual inspection (including 2D and 5D x-ray test) for the whole PCBA especially for
FPGA (U1_F1) and CPU, no process issue found
5)Captured the signals between FPGA and CPU, found CPU_LPC_AD<0/1/2/3> has any
abnormality after compared with a known pass board, the details as below:
6) Replaced FPGA with a new one, the failure symptom dis-appear
d)Device Purchase Order: 85YY73943
Hi Bruce,
Noted with thanks. Please be noted that the respective team will contact you directly for the next action.
Thank you
Chia Ling
- BWU157 years ago
Pls reply the emergency case in 24hours.Thanks! Best regards! Bruce Wu(SQE) Flex(Zhuhai) PCBA-B11/ Cisco Project Office: +86 0756 5183079 Mobile:134-2399-0614
