forr
7 years agoWe need a FPGA to generate 4096*2048(4K)video signal.
We have a display tester in designing which can provide 4096*2048(4K) video signal to display,to make sure the display can work normally in 4K resolution and different colors before shipment,please suggest a FPGA solution,thanks!
- Deshi_Intel
HI, Your enquiry is too generic. Perhaps you can elaborate further on your design requirement. For instance, if you are looking for video interface protocol solution that support 4k video, then you can consider either Intel displayport IP or HDMI IP https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_displayport.pdf https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_hdmi.pdf For FPGA device, I would recommend to use either Intel Arria 10 FPGA or Stratix 10 FPGA. Thanks. Regards, dlim- forr
Thank you very much, we will study the proposal you provided carefully and elaborate further on our design requirement later.
- Deshi_Intel
No problem. Glad to help out.
