SGora1
7 years agoWe have been granted to access to Intel DevCloud with 2 FPGA's connected. After connecting with the cluster via SSH, not able to see the FPGAs. How to view them and how to use them to run ML algorithms? Thanks in advance!
Hazlina_R_Intel
Contributor
7 years agoHi,
To make it work you have to execute the following instruction:
lsipci | grep accel
fpgaconf -B 0x3b hello_afu.gbs
Above works on nodes n137, n138 and n139.
I hope this helps.
- SGora16 years ago
I connected via SSH and tried running the above commands. They didn't work maybe because I am on the login node 'login-1'. By running 'pbdnodes' I am able to view all the compute nodes available but n137, n138 and n139 are not listed among those.
Kindly advise further. Thanks in advance.
