11 years agowave form/vector file simulation is not matched with logic
hi i'm a student and i made a baseball count program.
it is really simple. just same as ball count. so i made a logic with karnaugh map. and i finished the coding. but simulation is not working correctly. i can't understand. what should i do for this? here is code. all the sub-modules are working well. please tell me the problom of this. :cry::(
module base9(iRST, iCLR, iCLK, iHIT, iSTRIKE, iBALL, iOUT, oSTRIKE, oBALL, oOUT);
input iRST, iCLR, iCLK, iHIT, iSTRIKE, iBALL, iOUT;
output oSTRIKE;
output oBALL;
output oOUT;
wire PGH, PGS, PGB, PGO;
//pulse generate part
P_GEN0 GEN1(iCLK, iRST, iHIT, PGH );
P_GEN1 GEN2(iCLK, iRST, iSTRIKE, PGS);
P_GEN2 GEN3(iCLK, iRST, iBALL, PGB);
P_GEN3 GEN4(iCLK, iRST, iOUT, PGO);
////////////////////////////LOGIC part
wire DA,DB,DC,DD,DE,DF,DG,SO,FB,tempOUT,TO,SC,BC;
//strike part
assign DA = ((~B)&PGS) | (A&(~PGS));
assign DB = ((A&(~B))&PGS) | (B&(~PGS));
assign SO = (B&PGS);
//ball part
assign DC = ((~C)&PGB) | (C&(~E)) | (E&(~PGB));
assign DD = (D&(~E)) | (E&(~PGB)) | ((C&(~E))&PGB);
assign DE = ((D&(~E))&PGB) | (E&(~PGB));
assign FB = (E&PGB);
//out condition
assign tempOUT = (PGO|SO);
//out part
assign DF = (F&(~tempOUT)) | ((~G)&tempOUT);
assign DG = (G&(~tempOUT)) | ((F&(~G))&tempOUT);
assign TO = (G&tempOUT);
//clear condition
assign SC = ~((PGO|FB)|PGH);
assign BC = ~((PGO|SO)|PGH);
//////////////////////DFF part
//strike part
D_FF Dd0 (SC, iCLK, DA, A);
D_FF0 Dd1 (SC, iCLK, DB, B);
//ball part
D_FF1 Dd2 (BC, iCLK, DC, C);
D_FF2 Dd3 (BC, iCLK, DD, D);
D_FF3 Dd4 (BC, iCLK, DE, E);
//out part
D_FF4 Dd5 (iRSTn, iCLK, DF, F);
D_FF5 Dd6 (iRSTn, iCLK, DG, G);
////////////////////output logic
assign oSTRIKE = {(~DA),(~DB)};
assign oBALL = {(~DC),(~DD),(~DE)};
assign oOUT = {(~DF),(~DG)};
endmodule
module P_GEN(iCLK,iRSTn,X,Y);
output Y;
input X,iCLK,iRSTn;
reg Y;
reg state ;
parameter S0 = 2'b00, S1 = 2'b01, S2 = 2'b10;
always@(posedge iCLK, negedge iRSTn)
begin
if(~iRSTn) state <= S0;
else case (state)
S0 : if(X) state<=S1; else state<=S0;
S1 : if(X) state<=S2; else state<=S0;
S2 : if(X) state<=S2; else state<=S0;
endcase
end
always@ (state)
begin
case(state)
S1 : Y = 1'b1;
S0,S2 : Y = 1'b0;
endcase
end
endmodule
module D_FF(iCLK, iRSTn, D, D_out);
input iRSTn, iCLK, D;
output reg D_out;
always@(negedge iRSTn or posedge iCLK)
begin
if(~iRSTn)
D_out <= 0;
else
D_out <= D;
end
endmodule
1 Reply
Hi Sjin,
Perhaps you might need to elaborate further on your problem facing like error message or if the waveform not match, perhaps you could share the waveform result. Also you might want to put more comment on your codes. Also I believe it is important that individual module works fine as you mentioned. It would be the first step to make sure the design works. An important point on this is that for FPGA, the program isint sequential like in normal programming.
